Powermadd hand guards
HONDAFIXER
Londonderry NH
Anyone install the Powermadd handguards on their Apex? Wonder if the left side mount will get in the way of the parking brake. They have mirrors that mount on the end of the handguards that look like they will work good.
The mount does get in the way of the parking brake, but i think you may be able to mount it upside down to correct that......
Yep go under but you can go over you just end up with the hand grd's a little lower, I found that the mirrors out on the end stuck out too far and were too low, then all you saw was to much of the ground. They kinda lock in a little better high up.
This worked for me, but may not work for everyone else. Try taping them on 1st to see if you like it where ever it is you want to put them. Then mount them ;)!
My powermad mounts dont get in the way of anything.
I did mine underneath.......
i have mirrors so they stuck out too far if i did them that way...
Dan
