Apexpat
- May 13, 2014
- 2013 Apex
I did a search on this, not much discussion. I know it's recommended, but do I have to run 91 octane fuel? My old Apex and Rx-1 ran just fun with 87. Some places don't carry it in the UP. Will I run into detonation issues or cause engine problems if I get into a pinch and have to run 87?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
The older Apex, Attack, RX1 were tuned for 87 and it was the recommended octane in the manual. 2011 and newer are tuned for 91, as per the manual, but have a knock sensor which should allow you to run lower octane in a pinch. 91 is recommended.
Many on here have run both, in all generations without issue. Your default should be what is recommended in the manual.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
no problem running 87. i personally run premium as recommended all the time because it does get better mileage/ranch as well as better performance. you could always carry an additive if you are worried.
myrodman
- Feb 26, 2008
- NEW BOSTON.ILLINOIS
- 06 attak
05 warrior
I have an 06 attak but run the premium fuel because it has no ethanol I also add a little Yamaha ring free
- 11K
