Pressure wash engine??
Landoman
Pewaukee, WI
Can you pressure wash the entire engine compartment - obviously not at full force or you would blow the hoses apart but a nice light washing?
Any other ideas for cleaning up the entire inside? Not that it is that dirty - just want it showroom clean again.
I steam clean mine, no problems ever. Maxdlx
I would be very carefull with the pressure washer. I USED to pressure wash everything..... tired of replacing bearings because I blew water into the oil seals! I will not make this mistake again. Oil seals, orings, and gaskets are somewhat delicate..... good luck
