Reb-1
My 06 Vector's engine looks like it needs a good cleaning and then coat the metal parts from rusting? Trailered to northern WI for a week. Maybe all the slush we drove through got inside. Is it safe to go to a car wash and manually power wash the entire sled including the engine?
stomper
I pressure washed my rx1 and my wifes attack because of the same reason. I was just carefull not to spray too much around the air intake and electrical components. I never coated the engines with anything, just washed them.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
If you do it I would wait for a day with some warmth in the air, so all the moisture in the engine compartment will evaporate.
I also would not point the wand near anything with a bearing, for fear you drive water in somewhere is shouldn't be.
Wouldn't hurt to have had the engine running to ensure everything is warm in there to begin with.
Ms
Ms
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
In the spring, after warming the engine up, I spray engine degreaser from a spray can, around the lower engine, belly pan, oil reservoir and chain chaise. Let it sit then flush it with the garden hose. Everything comes up real nice.
Give it a try.
Ms
Give it a try.
Ms
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
after it drys spray it down with silicone spray. I would be very carful using a power washer tho. engine degreaser and just a hose should work.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
X2, I don't think I would either.yamahinn03 said:after it drys spray it down with silicone spray. I would be very carful using a power washer tho. engine degreaser and just a hose should work.
Althought it is hard to tell without pictures, I would be more apt to wash it down with a wet soapy rag with some type of cleaner (I prefer Citrus based) and see what happens first.
I would also go the route of maybe spraying it down with WD-40 and wiping it back up to see what it picks up?
When done, be sure to spray everthing down good with a good silicone spray lube and I would also disconnect all the electrical connections I could get to and either clean them based on condition then apply a dab of dielectric grease to them before clicking them back together.
Alatalo
- Jan 11, 2005
Pressure washing is for trucks and tractors. I would never use a pressure washer near any of my sleds or sportsbikes. All of them have seals that are for sure not made to withstand pressure washing.
