iasledder
Likely an old subject, but still looking for an answer. My '06 ER has never reached 10k rpm. 9700 seems to be about max with 800 miles on sled. All stock. So question, is there a slightly stiffer primary spring that would rpm increase the wot rpm without overly raising the engagement speed. I see some suggest removing rivets from the weights, usually the inner most rivet. I have no idea what the rpm gain might be. Have doubts that this would result in 10400-10700 where I would like to run. Tried new belts and have the deflection set so the track just creeps on the stand. Thanks for suggestions.---Jim
