Yamahashane
- Jan 12, 2016
- 2016 srviper mtx 153 mpi turbo
Sr viper mpi turbo 180 kit. I absolutely can not get my engagment rpm higher then 2800! Just put in Hauck Orange Primary 55, 2.75, 135. This doesn't make sense at all. Only gained 100 rmp from stock green green green spring. Keep in mind that mid and top are close to perfect. Help?
stingray719
Mine is set to around 2700 rpm and that is how I like it. If your sled will spin the track at 2700 rpm take off I am curious why you want it higher?
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
I agree with Stingray, I'm always trying to bring engagement down why do you want to raise it.
Yamahashane
- Jan 12, 2016
I just like the feeling of a bit higher engagment, my nytro was set like this but cant seem to get this one where i want it.. First time having a turbo and playing with clutching so it gets a bit frustrating when you cant think of anything else.! Lol still pulls like crazy tho!
What weights are you running?
Yamahashane
- Jan 12, 2016
Clutch kit supplied by yamaha, they did the installation. I tried a few primary springs and took some weight of the heel. Thats where im at now
Take a pic. Yamaha does not supply a kit. They do recommend Ulmer though. Are there rivets or washers held with small screws?
Yamahashane
- Jan 12, 2016
Yamahashane
- Jan 12, 2016
This is what they used i believe
I cant read the chart. If it is Ulmer just call him and tell him what you want. A different profile will do what you need. Like said most dont want the higher engagement but if you are drag racing and hooked up well or Hard core HillClimber with big track I would also.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I have an XTX with MPI turbo and Ulmers Clutch kit. It engages at around 3800 rpm. I have seen 9150 without spin. Kit works great as far as I am concerned. I am going to try the BOP spring for lower engagement as its a bit jerky when going slow.
bbquadrider
- Jan 22, 2014
Yamaha dealer supplied yamaha parts for clutch....weights rivets rollers and helix with my mpi kit
via big bad phone
via big bad phone
Must be new for this year. No Primary spring?Yamaha dealer supplied yamaha parts for clutch....weights rivets rollers and helix with my mpi kit
via big bad phone
bbquadrider
- Jan 22, 2014
No springs.
via big bad phone
via big bad phone
Yamahashane
- Jan 12, 2016
Yup exact same thing as me.. Would of thoygYamaha dealer supplied yamaha parts for clutch....weights rivets rollers and helix with my mpi kit
via big bad phone
do you know what primary spring they supplied you with? Or the specs of that spring? If not ill give them a call and see if they can help me.I have an XTX with MPI turbo and Ulmers Clutch kit. It engages at around 3800 rpm. I have seen 9150 without spin. Kit works great as far as I am concerned. I am going to try the BOP spring for lower engagement as its a bit jerky when going slow.
