Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Where can you go to get a good replacement bushing for the factory primary rollers?
Ty....
Ty....
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
how many miles on that bushing?
Doc Harley
- Oct 17, 2016
- Here & there
4200miles. But it spent the end of it's lifecycle practicing holeshots.how many miles on that bushing?
Fords4life
- Dec 7, 2021
- South Dakota
Thunder products works well for me.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Well Doc I'll give you my experience with the sidewinder primary.
The roller wear will get worse even to the point of one set of rollers a weekend.
Yamaha old bushings, new style bushings and TP rollers would not hold up over a single weekend.
I have a brand new set of G force rollers on the shelf for it but never installed.
I went with a Nytro primary.
I chased clutching on my sled.
Tried setups that others were using and wouldn't work for me.
I had very inconsistent clutching with the sidewinder primary. Its junk.
When I switched over to the older four stroke yamaha primary my clutching issues went away.
Been on the same set of rollers for the last couple of seasons running 270-300 tunes.
I even offered my clutch to Jared Smith for r and d but he didn't want it.
Doc Harley
- Oct 17, 2016
- Here & there
I see TP sells two different bushings. I'll give them a call.Thunder products works well for me.
Any advise as to removal from roller with basic hand tools?Ugh! Thanx Brendan
Yes, I've been reading up on this and understand.Well Doc I'll give you my experience with the sidewinder primary.
Going to go with rollers this season, and will prepare for the inevitable.
You say Nitro clutch, will Apex primary or others work as well?
I only ask so I can source the correct primary.
Is there a year that is better than others?
Thanx Tim
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Apex, fx nytro, and rs vector clutches will all work on sidewinder.
The difference in those clutches is some have set screws for the roller pins and some don't.
Good luck in your search.
Thunder Products clutching also builds and sells the older primary clutch. All brand new parts.
Doc Harley
- Oct 17, 2016
- Here & there
I assume we want the set screws?Apex, fx nytro, and rs vector clutches will all work on sidewinder.
Thunder Products clutching also builds and sells the older primary clutch. All brand parts.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The nytro clutch i am running does not have them.
I think it's more of a personal preference.
For replacement rollers for sidewinder clutch try the g force rollers.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Here is the link for g force.
SideWinder Archives - G-Force Division
gforcedivision.com
I've been using G force wider rollers. I like their weights also. Waiting for guys to rack up miles to get feed back.
I haven't been switching out clutches as I'm not seeing rapid roller wear issues.
I do split the clutches with miles and change out worn spider slides and shim as necessary.
I also grind down the end of the roller pin so it doesn't hammer back and forth as much.
Doc Harley
- Oct 17, 2016
- Here & there
Agree....this is my first worn bushing in 4200miles. So I'm not completely ready to give up on the factory primary.I've been using G force wider rollers. I like their weights also. Waiting for guys to rack up miles to get feed back.
Last season was torture on them. I'm hopeful this next season will yield less abuse.
I want to R&R bushing itself with TP bushing. Being a fiber bushing, I'm not exactly sure how much they can take.
In the end, during testing, It's probably more cost-effective to beat up on these TP bushings.
If that makes any sense....
Surprisingly, my clutches seem to be in very good shape.
Which I attribute to my natural riding style of taking it easy.
Thanx 74Nytro
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Doc Harley
- Oct 17, 2016
- Here & there
Good looking!If you go with the fiber bushings make sure to press them in straight and no hammering.
Don't want to damage them during install.
Here is a picture of the g force rollers with bronze bushing.
Tim....any secrets to remove bushing from roller using typical homeowner hand tools? Hmmm?!?!
Doc Harley
- Oct 17, 2016
- Here & there
Got it.
Again.... Just using them for testing purposes.
