Superman
- Jan 21, 2005
- Gaylord MI
- www.lakeffectsnow.com
For the clutch experts out there. My Attak has about 2,300 miles and the primary sheaves have some grooves in different locations. The worst ones are down @ engagement and another (not as bad) is somewhere around 3/4 the way up the sheaves. Has anyone else ever had this happen? The only reason I caught this is because I blew a belt @ 1,600 miles and I have NEVER blown a belt on any Yamaha I've owned. My clutching is 100% stock never touched. I have seen 11,000 RPMs alot this season. I also notice that my sled/clutching always feels snappier anywhere below full throttle. Based on what I see and feel "I THINK" I have a belt slippage problem causing the sheave wear.???? But how can this be???? Not enough primary weight maybe? a spring issue perhaps??... My Secondary clutch sheaves appear to be fine. I keep hearing that Yamaha is kind of anal when it comes to clutch parts. Any help and theories would be apperciated. Thanks.
Only change to my sled is the 1.5" ripsaw. NO Studs.
