PRO LINE HEELCLICKER OR ULMER> who is running them
rxwhopper
REGINA SASK> CANADA
jut wondering what guys arer thinking of them? i have a proline and a heelclicker 2 speed weight setup to try and was just wondering if i should leave it in stock forum for my first ride with it against the boys? hate to get my but whooped cause the clutching was all wrong,
Turk had a post about the 2 speeds and was fooling with them..
sounded like he was pretty close at the time...
any playing wit these yet? or should i say good feedback? i want to know some solid testing against a comparable stocker
I hear the drag n fly's with his black spring is rockin' ......
i treied randy,s 2 speed setup and its gonna take some playing. got beet by a stocker. i now put in the proline kits. see how that does. then i will bolt back to stock and try it. running a gps for speed to
what model 2 speed, what spring..what weights and when..might want to recheck it...
I see you mention gps...what are you after the most top end?
2 speed 38-20 with the black hc spring. randy had a 3 gram in tip and 3 in sholder. everything else stock/ i want good pull and top end. apparently you can get both with this weight according to supertorquer. 06 attak with 1.5 inch ripsaw
first off...apples to apples you WILL get beat against a stock sled with that 1.5 track IMO
your set up..
new belt or old
what secondary helix and spring ,wrap
what were your rpms..
what were the conditions...what was the temps etc
i can see that on the big end. not in the 660 foot area. it should have a better bite. i have taken 2 inch track and cut them down on mm 700 and it would take a good sled to beet him in 660. full bite is a awesome 660 tool. top end ya that one would fall right off quick
clickers
PM me what your using. Primary and secondary spring color, what the secondary is set at, and also helix angle. Have you weighed the clickers?
oh...you want to launch..
I wouldnt recommend that spring if you want 660..
also what is your secondary set up?
Did you get the whole Kit? Weights & springs on the Heelclicker II. I am running my RX-1 with a stroked Apex motor 1100 cc about 190hp. I have it dialed in with 2 washers and the screw on the rotating weight and jsut screws on the other 2 holes. I am using the white spring on the pimary and I think it is a yellow on the secondary (both came with the kit) in holes 3 & 3 for a 60deg twist. I have been running the Hellclicker for 2 seasons now even have one in my stock 05 RX-1 and an 07 Attack. The attack I am still dialing in only has 20 miles on it but am starting witht he same settings as the RX with the Apex motor. I am very impressed with the tunability & bite at 100 mph the skis lift when I hit the go button.
to me Ulmer is the tops in customer service...I only with this great service and terrific testing they sold the heelclicker stuff....I know that would be a real winner!
