Problem with my APEX need advice
y_guy
i have a 2009 apex. This past saturday i was riding along on the trails doing about 35 mph when the engine started to sound like it was running on 2 cyl. I stopped, and it would barely idle. I could keep it running over 4000 rpm's or about 25 mph but as soon as i stopped it would run on 2 cyl (sound wise) and then die. I could smell gas and there was some add'l smoke coming from the exhaust. This is the 2nd time this has happened to this sled.. when the dealer fixed it the first time they said it was fouled plugs. I say BS! to that. You don't foul plugs while blasting thru the trails on a 4S sled.
any ideas where to start?
With only 1000 miles on it?
What do the coil boots do
My 06 did this to me today. It was fine for 70 miles and then it just began to run like crap. I had to use the gas to start it after it died. It sounded bad.
Need help
Had this happen before...ended up being fuel line freeze up/crap gas...added some dry gas and ran perfect after..
