Mike Belanger
- Sep 22, 2015
- Belle River , Ontario
- 2017 LTX-SE Sidewinder
I have 2017 Sidewinder and I'm trying to go with 3 bar map sensor but with my luck the Plug on my sled is different....Any suggestions?
Are you sure your trying to replace the correct sensor?
Mike Belanger
- Sep 22, 2015
Most other Sidewinders both barometric and map sensor are the same but mine is not
odd
Mike Belanger
- Sep 22, 2015
for sure...just don't get it...i'd post a pic but not much of a tech to figure it out lol
Mototown
Where did u buy the sensor?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
My barometric sensor and MAP sensor are not the same plug. The MAPsensor is towards the middle of the sled
Mike Belanger
- Sep 22, 2015
Always deal with Dave ( Hurricane ) was on the phone with him all day don't make sense to him either
Mototown
I would check on line parts , check wire harness #. & sensor. Might be able to change that section of wiring
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Mike Belanger
- Sep 22, 2015
No have no cleared it up but made it work lol....have the same 3 bar map sensor but my plug on the sled is different, the 2 tabs on the side of your 3 bar my plug on the sled has the tabs closer to the top...not in the center like the 3 bar so I used a Dremel and shaved the tabs off...don't understand why my wire harness is different on my sled.
- Nov 29, 2009
- sabattus, maine
Maybe an early buildNo have no cleared it up but made it work lol....have the same 3 bar map sensor but my plug on the sled is different, the 2 tabs on the side of your 3 bar my plug on the sled has the tabs closer to the top...not in the center like the 3 bar so I used a Dremel and shaved the tabs off...don't understand why my wire harness is different on my sled.
baggs66
Can you install the 3bar sensor on stock sled and run with no problems? I will be adding my tunes after some breakin but would like to install this and my bov to have done now.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
No you can't, nor is there any reason to run a three bar map sensor on a stock tune. The tunes are reconfigured to run the 3 bar sensor. It only take a couple minutes to switch it out anyway. Same with the BOV takes a couple minutes to swap out.
If you're running stock then just run stock stuff. Nothing to gain switching even the BOV on a stocker. Do it all at one time.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
No, your ECU will not know how to properly read that sensor.Can you install the 3bar sensor on stock sled and run with no problems? I will be adding my tunes after some breakin but would like to install this and my bov to have done now.
- 7K
