Looking for some help! 2018 sidewinder with Turbo Dynamic flashes, 3 bar map sensor, blow off valve, CAI, sock muffler. I have a P1236 error. I have researched on this site and have done the following. Boost tested system and tights clamps, boost holds well. Attached is the boost and boost map data when at idle. Do those numbers seam correct? How do I get rid of the error? Sled runs fine just trying to get to the issue if any.
Mike
