snoman
been running into code 30 since the day i changed oil and tipped the ride tot he left side oil tank up and drained the oil out of the system still code 30 and the sensor in front of motor was leaking before and took it off the motor and plugged the hole and stopped leaking could it be the sensor causing this problem ? need some pro's here thanks.
snoman
ANYBODY ?
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
you took the sensor out and plugged the hole. Does this mean the sensor is no longer in the block or no longer hooked up. If yes theres your problem. Maxdlx
The Artist
I have seen oil sensors leak before
- 54K
