problems with RX1 starter drives????????
northern summit
Dawson Creek B.C
Mine left me stranded expensive chopper ride out .Could not start
manually. Starter ran just didn`t turn the motor over?
Anyone replaced the drive does not look like a conventional starter drive.
Does the drive press off with the ring gear?Anyone have torque specs for
the flywheel? :4STroke: not today
You can pull the starter on the hill and pull start the sled using a piece of webbing around the primary. They start pretty easy if they are not flooded.
Rx1M5
used a piece of starter rope would not start ,my sled does not start that easy .
You have actually done it yourself?
would have worked at it alot harder but did not think it could be done
There are a few posts of people successfully starting an RX with a strap wrapped around the primary. I carry a strap but have not tried it.
There is even a video linked from this site of a guy doing it on his new Nytro.
While a cold turbo rx1 may start with the rope, mine when warm seems to need to turn over more then you could possibly do with a rope before it will flash. for a $1000 bucks i would wait till it was cool and try.
tried warm and after sitting for a couple hours
kinda glad I did not start it found the bolt heads and one was in the
bottom of the crank case wouldn`t have wanted to start it with that in there.........
