tonykof
Having some trouble pressure checking my buddies Bender Turbo. We made an adapter to hook up to the turbo to check the system from the turbo forward. He thinks its leaking through the turbo & up the exhaust pipe & into the motor. I'm thinking this is not the case because I would think that would mean the seals were shot & if thats the case would it also be burning oil big time? Also, it seems to totally flood the motor big time.. We are putting about 15lbs of pressure on it.. Is the proper way to do this? Should we be checking one component at a time? We can't seem to get more than 10 lbs out of the turbo. Tried shortening the rod length, plugging the actuator to turbo hose etc... Maybe the turbo is weak? Any suggestions would be appreciated.
Tony
Tony
