stone88
You have to remember your sled is a supercharged Sled ours are Turbos they require different set ups. Your sled delivers power instantly while mine takes a second or 2 to spool to full boost. I've had both and even suspension set up is different for both. We launch between 3400-3800 rpm
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
now that is interesting. lower launch rpm, thats a start.
track hookup is okay. at least for now, the only thing spinning is the belt.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
today, went back to napi..
Worked on clutching... got her to grab that yamha belt for good now! but started having traction problems...
then solved traction problem...
and I am now right a 1.30 60ft time
Was running out of gear and engine rpm by end of track a 156mph.
My last run was a 8.56 (or 8.58??? nor sure) @ 156mph and sled started spinning track a little after the 60ft mark... (did not make a good burnout on that one... my fault)..
anyway, I have now figured out how to lower those ET on that pig heavy sled
stone88
Good to hear. Did you change your engagement and if so to what rpm?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
3900-4000 rpm is the engagement now.
learner how to tune the 4 secundary arms on the rageVIII clutch... (which I never really did before) and some judicious tuning adjustments
Now I would need to get rid of some pig on this sled...
stock yamaha steel suspension brakets which weight a ton, exhaust weight a ton, seat too...
Is there an easy way to install a small gaz tank in the stock tank? because I always run 5 gallons or so or gas in there to avoid fuel problems... that is 30 easy pounds right there too.
Anybody have weight reduction ideas for me?
sled is weighting with 5 gal of gaz around 720# right now. would like to get it down around 620-630.. but don't want to sacrifice the appearance too.
Low 8's with same power might be possible if that weight goal is attained.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
My last run of the day:
http://www.youtube.com/watch?v=KK06wESC ... e=youtu.be
still a little bit too much loaded on the start.. but I dont think there is much more to get out of such an heavy sled on the 60ft... maybe 1.25-1.26... ???
How much hp does a supercharged sled makes at 23 psi boost and 11500 rpm typically?
I only dynoed this sled at 28 psi of boost... and it was 380hp at 10800 rpm...
