monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
- I'm getting ready to pull the skid on my 08 40th LTX GT and want to ensure I do it right.
- Any think I need to be aware of before I dig in?
- I want to get the skid out, get the shock revalved.
- All help is greatly appreciated!
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
monte1214 said:- I'm getting ready to pull the skid on my 08 40th LTX GT and want to ensure I do it right.
Just be careful with your girly hands John and all should go well
http://www.ty4stroke.com/viewtopic.php?t=42869
monte1214
- Apr 20, 2005
- Durham Region, ON
Irv said:monte1214 said:- I'm getting ready to pull the skid on my 08 40th LTX GT and want to ensure I do it right.
- Why not get your azz over here and help me!
- Get off the forums for awhile!
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
I'll see what I can go, or did you get it out already?monte1214 said:Irv said:monte1214 said:- I'm getting ready to pull the skid on my 08 40th LTX GT and want to ensure I do it right.
- Get off the forums for awhile!![]()
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
i would be sure to disconnect the wires for the shock and rout them into the skid before strating to remove the skid
monte1214
- Apr 20, 2005
- Durham Region, ON
thor452 said:i would be sure to disconnect the wires for the shock and rout them into the skid before starting to remove the skid
- It's the shock that's bothering me about all this.
- I know to remove the wire, but should I have the shock at the minimum or maximum setting before doing it?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
it dont matter.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Not with the Ohlin's?thor452 said:it dont matter.
Different shock I know, but I remember reading full hard with mine.
How did you make out John, did you get it out?
monte1214
- Apr 20, 2005
- Durham Region, ON
Irv said:Not with the Ohlin's?thor452 said:it dont matter.
- I read full hard on the Mono too??
- I haven't touched it yet Dale. I got my car back today, and have been out cruising!!!
- I hope to get at the skid next week. I've spoke to Dean at Peak, and he said anytime is good.
- I wanna get it done soon. Still undecided about the powder coat???
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
i have pulled 4 diffrent skins with the ohlins ec two of them being mine and never had a problem with it the cpu always remembered where it was set when i pluged it back in.maybe there is a precaution i dont know about. my experiance has been that it didnt matter at all where it was set look in the service manual if you need to be certian.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
On the ohlins shock you can disconnect the wire and not worry about your setting! As thor mentioned the computer will show your exact setting after you get it hooked back up. On the standard mono shock you have a manual adjustment that needs to be timed with the dial and the shock. On the ohlins your fine.
