Windsor Sledder
- Nov 6, 2015
- Windsor,ont
- 2013 Yamaha vector ltx
Looking to upgrade my 2013 vector. Thinking a Viper. What is the difference between a 2014 and 2017. I want a 137 in. With coil springs on the front. Thanks
Yamadog
That's a loaded question there are so many viper models and all have been changed in different ways. The motor has also changed in 16 and if your thinking of turbo stay 14 or 15. There also has been at least 3 ecu flash upgrades in 5 years for idle, starting and other reasons.
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
I am looking at a couple of LTX SE . I like the seating height but not sure about no power steering. I have not had a chance to try one.
Yamadog
I am 57 and have 2 turbo'ed XTX's they are a handful but I would never add power steering. I have ridden many ltx's and only 1 that was set up poorly was a bit hard to turn. I have 144 picks on my trail sled with tuner II skis with 8" carbides inside and 6" out side and never have arm fatigue
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
It is good to know that your arms do not get sore . I am afraid of that. Hopefully i get a chance to try one before end of winter. If not more than likely will buy one and play with suspension. ThanksI am 57 and have 2 turbo'ed XTX's they are a handful but I would never add power steering. I have ridden many ltx's and only 1 that was set up poorly was a bit hard to turn. I have 144 picks on my trail sled with tuner II skis with 8" carbides inside and 6" out side and never have arm fatigue
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
My brother has a 16 LTX SE and I can tell you this, it steers like it has power steering. So easy and effortless, glued to the trail like a slot car. That sled handles like a dream. Now with that said he does have some upgrades that make it what it is. Changed skis to curves with 6" bergstrom triple points and upgraded air shocks to QS3r's all the around. Shocks also improved ride quality and big bump capability 10 fold over the air shocks. I would find one that has either the QS3 (16's) came with these or some other year model LE's also had the QS3. I do know the 18 LTX LE 50th Viper came with QS3r's, both the QS3 and QS3r are hard to beat on this chassis. My sons 16 RTX SE came with QS3 from the factory, we changed to the cat ski with bergstrom triple points and it also handles with ease and glued to the trail.
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
GreatMy brother has a 16 LTX SE and I can tell you this, it steers like it has power steering. So easy and effortless, glued to the trail like a slot car. That sled handles like a dream. Now with that said he does have some upgrades that make it what it is. Changed skis to curves with 6" bergstrom triple points and upgraded air shocks to QS3r's all the around. Shocks also improved ride quality and big bump capability 10 fold over the air shocks. I would find one that has either the QS3 (16's) came with these or some other year model LE's also had the QS3. I do know the 18 LTX LE 50th Viper came with QS3r's, both the QS3 and QS3r are hard to beat on this chassis. My sons 16 RTX SE came with QS3 from the factory, we changed to the cat ski with bergstrom triple points and it also handles with ease and glued to the trail.
Thanks for the info. So he went from coil overs to all air shocks . Interesting
DennyTuna
- Jan 28, 2017
- Ohio
Ah no...upgraded from the air shocks to QS3r's.
Windsor Sledder
- Nov 6, 2015
- Windsor,ont
Ok. Thanks. I was just looking up those shocks. They look pretty impressive. I will keep that in mind when I buy oneAh no...upgraded from the air shocks to QS3r's.
