hypertxer
my sled is pushing in corners i just ordered carbides for t i have c@a pros on it but what else should i do to it to make it rail or is it gonna be fine with new carbides
RTX Rox
What's the floats set at?
55-60 PSI in the floats and tighten the limiter strap one hole. This should make you rail nice.
Blue Oval
- Feb 22, 2006
- Westminster, Ma
- snyderpools.com
Try going to 35 PSI with the limiter up one and the front skid shock set real loose. Try the "new" pipe fix for your skis too. this is going to surprise alot of people!
RTX Rox
That's insane, 35 psi in the fronts. I listend to someone on here about that and tried my floats at 50lbs and it was HORRIBLE. I put it back to 75 lbs and it rails. Plus, with the arms almost being parellel it not only pushes like crazy in the trails but the drag in a straight line is terrible.
