donkickit
- Sep 23, 2007
- Upstate New York near Albany
- 2014 viper ltx se
Yesterday, ran the rtx in about 8" of wet snow. I noticed the front end is actully accumulating snow and pushing it along (also slowing it down)
it accumulates around the a-arms.
My front shocks are at 75, rear clicker full, spring on H. Seems to be sitting a little low in front? What would cause that?
sniperviper
Change to wider skis, you need to keep them on top of the snow. My last year Phazer did exactly the same before I changed the stock skis with something wider.
TripleThreat
^^^^^^Ditto.....the stock skis are too narrow to support the weight of this sled. Bolt on wider skis and you'll see a whole new animal.
LJ 452
Yes get some new skis (USI Tripple Threats worked for me) set the floats to 60-65 and enjoy.
giddy up go
- Oct 7, 2007
- Lindsay, Ontario
- 2011 apex er
Maybe a foolish question here, but when you adjusted your float shocks air preasure your ski's were suspended off the ground correct. I had the same problem front end low when I took out the sled on it's first run. I didn't read the manual close enough and adjusted the air shock with the ski's on the ground. Adjusted them properly and it took the front up and rode much better. Just a thought!
