hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
Adjusted my rear qs3 shock from 2 to 3 cause trails were really rough and all was good till next day when I went to put it back to #2 position and now there is no notches or feeling of clicks, just is free moving. What would be the cause ?
snoprof6
- Mar 26, 2007
- Upstate NY
- 20 Indy XCR
16 Zr 6000 LTD
02 Sx Viper
02 Sx Viper
The rezi has lost nitrogen. The factory end cap uses an aluminum c-clip that hold in the end cap. Repetitive movement and pressure wears it out and causes leak down. Hygear makes new end caps to prevent this issue. I had the same issue with my shocks and sent them to them. No issues thus far this season (500 miles)
https://www.hygearsuspension.com/collections/fox-bodies-and-res-tubes/products/fox-reservoir-cap-2-0
https://www.hygearsuspension.com/pages/fox-reservoir-cap-service-alert
Added a second link as well to better explain.
RAMSOMAIR
contact Cannondale27 here, he does this also.
snoprof6
- Mar 26, 2007
- Upstate NY
- 20 Indy XCR
16 Zr 6000 LTD
02 Sx Viper
02 Sx Viper
cannobdale27 is far faster in my experience as well
hognit09
- Mar 7, 2010
- beaver dam, wi.
Was planning on having my shock rebuilt by Cannondale27 at the end of this year. Will it be ok to ride on the rest of season for another 500 miles ?
No. It needs to be fixed if charge is lost which is what the knob with no clicks indicates. I can get it done in less than a week. Parts are all on hand. You arent that far from me. If you can get here during week I can do it while you wait. Weekend I am riding!Was planning on having my shock rebuilt by Cannondale27 at the end of this year. Will it be ok to ride on the rest of season for another 500 miles ?
Been preaching about this issue for years.The rezi has lost nitrogen. The factory end cap uses an aluminum c-clip that hold in the end cap. Repetitive movement and pressure wears it out and causes leak down. Hygear makes new end caps to prevent this issue. I had the same issue with my shocks and sent them to them. No issues thus far this season (500 miles)
https://ty4stroke.com/threads/fox-qs3-and-resevoir-shock-issue.151695/#post-1409218
hognit09
- Mar 7, 2010
- beaver dam, wi.
Ok, will be getting them to you soon, i will give you a call, thanks
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Can someone comment on getting this work done in Manitoba. I have the same issue on my MTX
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
https://bouwmanent.ca/ he is in tyndallCan someone comment on getting this work done in Manitoba. I have the same issue on my MTX
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
