dirkdiggler
Suspended
Have you ever considered running a bottle blanket to keep the consistent Bottle pressure even though holtman's nozzles are suppose to compensate?
- Apr 14, 2003
- Hessel, Michigan
Hey dd - The only time I used the bottle blanket, was when I ran my own setup, which included Nitrous Oxide Systems components. The system NEEDED to be warm, 70 or above to work well, otherwise it would surge, or bog after the button was hit. The other reason, is that the way I have the bottle mounted on the 05 RX1, and APEX, I wouldn't be able to get a blanket over the clamps. Makes for easy removal also, without the blanket.
dirkdiggler
Suspended
thanks for the quick reply.
AIRWOLF
Guest
Terry,
where did you mount the bottle on the Apex?
- Apr 14, 2003
- Hessel, Michigan
HAHA Nice man!! Go get them!!!
Skydog
Skydog
- Apr 14, 2003
- Hessel, Michigan
Update, Ran thru the radar gun at 127.6 mph Staurday 12/3/05 with the Attak. Run was just over 1/2 mile.
System was still too rich, as I like to start out a little rich, then lean down so no bog, or dropping of rpm's.
