Todd Beenen
What are you guys seeing at idle for afr ? On TD’s site it says low 11’s at idle, mines at mid 12’s, just wondering in my sensor is bad, or that’s fine?
no1b4me
That is fine, what you need to monitor is WOT afr and cruise.... Mid 12's at WOT will produce the most safe power...What are you guys seeing at idle for afr ? On TD’s site it says low 11’s at idle, mines at mid 12’s, just wondering in my sensor is bad, or that’s fine?
Todd Beenen
Roger on that.
Todd Beenen
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
soo we had a thread on this last year both myself and Knapp are seeing only in the 11-12's while warming up, after that ours were in the high 13's
Todd Beenen
I must have missed that thread, thanks for the info
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
Would say normal, don’t worry about idle afr too much if running good. Also the closed loop does not adjust at idle it is speed activated.What are you guys seeing at idle for afr ? On TD’s site it says low 11’s at idle, mines at mid 12’s, just wondering in my sensor is bad, or that’s fine?
- 6K
