Does anyone know if anyone is installing a 2 into 1 header and useing a
R-1 Slip fit silencer straight out the back? I would think they would be lighter and possibly cheeper if one can cut the stock exaust off at the x-over and run a straight pipe back to a slip fit muffler on thier own. I thought i saw something like this before on a post mabee.
Like this? If so contact CBS Performance 250-769-8212. 20lbs lighter than stock. Naturally louder so if you are in a sensitive area....don't do it.
Loose the tailight as well so you may need to find a small LED set up for the rear of your sled.
Good luck
CM
