RA Cable binds?
z28rx1
Western N.Y.
Got my shock back from bruce at pioneer (re-valve) and installed with new r-a cable and cant get the cable from binding while adjusting.The cable should be routed thru the loop on the skid rite?
Are you sure the adjuster in the shock is set in the correct position before installing the cable? Mine did the same thing and the adjuster in the shock was already at the end of the adjustment but the dial still had half of the adjustment left.
ya, i found out that the cable does not turn the same way as the dial,so after i figured that i have all 22 clicks but cable still binds.thought of zip-strips but didnt think that was a good idea thinkin it should move with the suspension :o|
