I will be asphalt racing my MC Xpress turbo sled very shortly and since they are banning leaded fuels I figure I might as well get on the unleaded race fuel program. Does anyone know or have any experience with any of the VP unleaded fuels and what would be the best fuel for my application, I will be running up to 19#'s of boost with lowered compression.
All I have ever used in the past is the C-12 which has always been flawless, any suggestions?
HURRICANE
We are thinking about the same issue.109 is available.That will work well with meth injection to raise the octane
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Is there a fuel that is about equivalent to vp import but UNLEADED?
I would need this.
I would need this.
DC5
mulot30th said:Is there a fuel that is about equivalent to vp import but UNLEADED?
I would need this.
Not likely, but the leaded fuel ban should be lifted in a couple of months.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
How much time ca we keep vpimport fuel in sealed barrel?
DC5 said:mulot30th said:Is there a fuel that is about equivalent to vp import but UNLEADED?
I would need this.
Yes it will but it's only temporary and then we are done so might as well work with what we are going to be forced to use.
DC5
DC5
I think they are going to lift the ban indefinitely and only consider banning it again if the US does.
http://www.canadagazette.gc.ca/rp-pr/p1/2010/2010-04-03/html/reg2-eng.html
DC5 said:I think they are going to lift the ban indefinitely and only consider banning it again if the US does.
I was told the US will be banning it with in the next year or so.
So what is the best unleaded fuel?
TurboJamie
Av Gas!
TurboJamie
TurboJamie said:Av Gas!
The highest non leaded fuel I belive I could get before was VP MS98L I ran that in my head shimmed apex up to 18 psi.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
MS109??? isnt it better?
If we don't have good unleaded race fuel...
I think I will end up switching th full methanol as fuel. Now this is octane.
There is always propane??? might be a good alternative too.
TurboJamie
I heard there is MS109 now, at the time they didn't have it.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
I tried ms103 2 years ago..
with 10-1 compression, stock timing, max boost before detonation was about 16 psi.. but that was using the boondocker's turbo system which is notorious to keep heat where is does not belong.
TurboJamie
Mine was PL with double down and excell exhaust.
