SAINTAL86
- Feb 3, 2008
I have an 03 RX-1javascript:emoticon('
I have installed Fit Power Sports racing cams. I lined up the fly wheel hole marks, checked with dial indicator for top dead center, removed cams according to repair manual.
I made sure they were lined up and facing away from each other. I made sure chain did not move timing, tightened up bolts, put chain tension er in and released spring adjustment.
Started the motor, after it warms up and we start pushing the throttle it started running rough and stalled. We removed the air filters, found air filter got wet with gas and it was not getting enough air .
When we removed the air filters and restarted thats when we saw the gas mist coming out of carbs at any thing over 1/4 throttle.
We double checked everything and do not see what we could have done wrong. Could we be 180 degrees out of time? Would it run that way? with no belt on it the tach. will go to 10,000 rpms, has no power ,, to go, and it sounds flooded not sounding the way it should. HELP.!!
ANY ONE.
AL
ANY ONE.
AL
DC5
With the filters off seeing gas mist coming out of the carbs is completely normal. Are you using the marks on the cams or the cam sprockets to set the cam timing?
kinger
These are Fix powersports cams? do you know the differences from stock?
Sounds like a cam timing error to me
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
kinger said:These are Fix powersports cams? do you know the differences from stock?
Don't the bike cams and the sled cams use a different firing order? You need to move a couple of coils to different cylinders?
kinger
u ever get it figured out?
