radiator delete question
yzviper366
BISMARCK, ND
Before I screw something up I thought I had better ask. I am getting rid of the rad and putting a bottle in its place. Is there any re routing of the coolant flow needed? Or can I just Hooke the two hoses that went to the rad to the bottle and call it a day?
Thanks guys?
OK cool I'm doing almost exactly what you did just a bit different under tunnel cooling. I think I even have the same bottlu had. Did you have overheating issues at all? And did you get any codes after removing the rad fan?
In this thread you can see my under tunnel cooling. Should b enough I think.
http://www.ty4stroke.com/viewtopic.php? ... c&start=15
What you did will work well. Similar to mine.
