Generally speaking, Yamaha uses a 60* twist on all of their sleds. I do not know what the lb pressure is as I never measured it, but the higher the twist, the higher the pressure applied to the belt. That is why the engine RPM usually goes up, or down, a couple of hundred with each 10* of twist.
