sherlock29
Hey guys... I've searched... but no luck. I'm looking for some pics of rail mounted ices scratchers. I picked up a set on the weekend, and can't seem to find a suitable place to mount them. I'd like to mount as far forward as possible on the rails, but want to put in the right spot.... so guys that have them any way to post up some pics, or idea's??
thanks in advance
sherlock.!!
thanks in advance
sherlock.!!
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
on my attak i had to drill holes.
sherlock29
i have no issue with drilling holes... where did you mount?? I'm really toying with the idea of mounting on skis.... but need more input on what is working... my boot heals are almost wore thru... hehe
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
What type or kind of scratchers did you get? That info will help with suggestions.
yamiboost
- Feb 17, 2008
- Labrador,
mine is just in front of that rubber on the rails. i cant seem to find a good pic. the more forward you get them the better. some guys remove idlers to install them.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
If you are using Side Kicks (the cable type) that is what I have and am pleased so far. They make a big difference on hy-fax wear 3-4 times longer than without them. On my Nytro, I drilled a hole and mounted just behind the curve on the rail. When I put them on my Apex I put them on the lower inside of the A-arms so the snow would be kicked up sooner, on all of the rail instead of just the back 2/3rd of it. I like that better and have had no problems with them up there. Also the guys I ride with like the location on the A-arms better. Not as much snow and ice chips being thrown up at them when they are following. I get alot of complaints from the ones on the Nytro that are mounted on the sides. Hope this helps.
sherlock29
the ones i bought were the conventional metal rail mount type... bought them at royal..
http://www.royaldistributing.com/main/i ... Number=173
I'm just wanting to add them as far forward as posible, but seems wheels need to come off first. or completely... not interested in removing more wheels...
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
I tried a set like that first, they didn't last 10 minutes, I forgot about them and got in a spot I had to back-up and they were trash. Thats when I went to the side kicks and have them on for 3 year and no problems. Hope you have better luck with that type than I did.
VectorLTX2012
Agman 57 said:I tried a set like that first, they didn't last 10 minutes, I forgot about them and got in a spot I had to back-up and they were trash. Thats when I went to the side kicks and have them on for 3 year and no problems. Hope you have better luck with that type than I did.
Agman
Did you mount one or two on your sled? I've read somewhere that if you mounted one on the left-hand side of the sled it will unscrew and come off. What did you do to stop that from happening?
Chester
I've seen 2 sets of the rail type broke by going to back up with them down. They do work good but I'm going to try the sidekicks on the a arms.Agman 57 said:I tried a set like that first, they didn't last 10 minutes, I forgot about them and got in a spot I had to back-up and they were trash. Thats when I went to the side kicks and have them on for 3 year and no problems. Hope you have better luck with that type than I did.
VectorLTX2012
gouldsjett1 said:I've seen 2 sets of the rail type broke by going to back up with them down. They do work good but I'm going to try the sidekicks on the a arms.
When you get them mounted on the A arms can you post a picture of that? I'd like to see how that works.. Where do you hook them up when you're not using them?
Chester
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
Mine...
VectorLTX2012
monte1214,
That looks good to me. Did you locktite very thing so they don't loosen up?
Chester
Chester
monte1214
- Apr 20, 2005
- Durham Region, ON
- Yep!
john10toe
A buddy of mine mounted his to the side rail (running board) and he ended up with a bunch of cracks migrating out from the 4 attachment screws. I attached a picture………sorry it is not very good taken a while back with my phone. Not sure the best place to mount them but I am certain this is the wrong place after seeing his running boards crack. I went with Hartman’s ski mounted ones and attached them directly to the (pilot) ski spindle bolt. Pull up and clip over ski rail when not in use......
http://www.hartmaninc.com/scratchers.html
