Boomer
I picked up a Ram mount which I want to mount to the riser. How did you guys who have mounted one of these to riser, attach it? Are you screwing right through and lock nutting it on or tapping it out and threading a screw in. I have a stock 08 vector GT and not even sure yet if the riser is hollow.
I want to be able to mount it so the GPS swings up and rests just above the pad.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
I drilled two holes through the riser and used a bolt with a nut .Mine is mounted on the front so the gps sits up and in front of the pad.
scherbs
- Apr 1, 2007
- S.E. MICHIGAN
- home.comcast.net
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
I mounted mine so it was offset a little so that it was away from the gas cap, but mines a Nytro. Drilled and tapped.
bankershrs
- Sep 19, 2008
- Roscoe, IL
- 2017 Yamaha Sidewinder RTX LE
Scherbs,
Looks like you used a marine mount, correct? If so, it holds through the rough stuff?
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
I also drilled into the riser. I thought that I would have to tap the holes, which I guess would be the proper way to go - but I found that the metal is soft enough that after drilling, the nut sort of "self-tapped" the hole on it's own. I fasted with two lock nuts on the inside.
I've had no issues so far with the mount becoming loose while riding down the trail.
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
I drilled an tapped mine. works great
04rxw10
- Jan 28, 2008
- Lisbon Falls Maine
- androscogginubm.org
My Lakeffect Riser has one with it.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
mine is mounted on the handlebars - i use it on my trek in the summer
blustar
- Mar 11, 2009
- Manitoba
- members.shaw.ca
- Yamaha Apex and RS Vector
Gee Woolyviper, all you need now is a 7" color monitor on the other handlebar and a Dish network satellite on the back and receiver and you will have it all!
Just kidding !
Just kidding !
Nick1945
