RB3 How it works
RB3 box has a wire harness for Apex or Nytro etc.
Harness has been upgraded to be able to run naturaly asperated or boosted. by changing a single wire connector.
Boosted sleds need to plug into a map sesnor whcih we have 2 or 3 bar map sensors.
2bar is up to 15 PSi 3 bar is 27 PSI
As soon as sled fires up it runs on map if mapped properly.
Once mapped no need to adjust for different boost levels or changes in alitude etc.
The harness plugs into Injection connectors, Pulser wire conectors for timing control. Key switch for power, and has a couple black connectors with single wires for Stutter button and switch maps.
Brown is stutter
Gray is switch maps.
Install a RB3 on rear mount MCX and you can add Ignition timing for way better throttle response and pull timing with boost for more power and run at different boost levels.
MCX uses 4 extra injectors that have only one set of wires controling 4 injectors so that when MCX box senses boost it kicks on all 4 injectors at same time and they have no timing control on injectors so they just spray and load up and give you lag like feeling untill it cleans up and then comes on hard.
Dobeck which makes the boxes that MPI, PureLogic, Attitude, Old PowderLites boxes etc. get power from injectors! Low voltage or hard starting cause poor running sled where they missfire and sometimes even stall when letting off throttle etc.
RB3 can pull fuel for bigger injectors and make power like a stand alone system that would cost about $5000. us funds. No need to buy MSD Ign. System cause RB3 does all that a stand alone does and more.
Boondocker may have changed from old stuff they had but only could run 85% duty cycle on Apex and no load base and runs a step system. Most guys went to Dobeck box like Outlaw Motorsports etc. to make there kits run better.
RB3 can be adjusted from Laptop with lite software or prolite that comes with USB cable. Or with new Bluebike using Bluetooth that uses Windows Mobile 6 Celphone,
Hope this helps clear up some questions.
http://www.powderlites.com
