Rattle in exhaust 03 RX-1
mxkelly
Just got the sled fired up today and I have picked up a rattle in the exhaust around the back of the sled, sounds like a gaurd or baffle vibrating when its idling and goes away when its reved up, has someone had the same issue? Thanks :yam:
Could be the doughnuts also......Happened on 2 of my sleds so far. Removed heat shields and the rattle changed. Went from heat shield rattle to exhaust rattle from worn doughnuts. Plenty of threads on here about this. Not a bad job if you have mechainical ability.
:4STroke: :yam: :rocks:
it is the doughnuts i had the same problem they ware out and the clamps rattle it was on my 2004 rx1 warrior
Check the coolant cross over tube in the rear of the sled . The rivits loosen up and that rattles to.
All of the above are good potential sources of the noise. Recently, my tunnel protectors [Square Tubing] were loose and rattling.
To check the exhaust donuts, have someone hold their hand over the exhaust tips and look for exhaust coming up from under the front of the sled/tunnel. This works best when the sled is cold and emitting a lot of vapor.
Found the problem guys, it was one of two things 1) Rivots that hold the cooler pipe between the two back hoses were loose and that pipe was really rattley 2) One of the two cross brackets that run down the twinned pipes before the muffler was broken, fixed both... rattle gone... Thanks for all the input we were in the right area!!
