Mark Vance
- Oct 5, 2017
- Woodstock, ontario
- 2018 Yamaha Sidewinder LE
Can anyone tell me the torque spec for the bolt that clamps the rear aluminum pivot arm to the Rear top Suspension arm? I had to remove the top rear idler wheels to replace them. 2018 Sidewinder LTX-Le 137. It has a 13mm nut and 10mm bolt.
Torque spec sheet I have it wasn't clear and didn't want to over or under torque.
PS 9800 miles on the original top idler wheels and bearings! not bad.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
45 ft/lbs
Mark Vance
- Oct 5, 2017
Thanks for the reply... this is the bolt I am try to determine how tight to torque. It wasn't very tight when I removed so i don't want to over tighten. Thanks again.
earthling
I think those small lock nuts are 20ft lb.
Mark Vance
- Oct 5, 2017
Thanks... much appreciated!
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
20 ftlbs is correct.
DMCTurbo
- Nov 12, 2005
Ok I was thinking the bolt to fasten it to the tunnel.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Most of the fasteners on these cat skids are like 10mm and 13mm. They dont need a ton of torque. A decent 3/8 drive ratchet and make snug, tight and one more little bit - and that will be an easy 20ft lbs.
MS
MS
Mark Vance
- Oct 5, 2017
Thanks... much appreciated everyone!
- 35K
