RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Hey all
This past weekend i tore the shock mounts off of the rear arm on the mono suspension (2006 apex rtx)
i had the beef up kit done to the front arm and now i think the rear arm might become the weak link. I wanted to upgrade to one of the newer arms that have the track rub preventers on them.
it looks like 2006 &2007 are the same# 8fu-47332-10-00 (no rub preventer)
2008 is a different # 8fu-47332-11-00 (no rub preventer)
2009 changes again # 8fu-47332-12-00 and has a rub preventer (tube welded to the arm
2010 changes again #8ja-47332-00-00 and has a rub preventer (tube welded to the arm
2011 changes again # 8jb-47332-00-00 has a rub preventer (welded brackets that hold plastic rub preventers)
Does anyone know if an arm from 2009 - 2010 or 2011 is interchangable with the 2006 mono suspension .
I would like to be able to just drop in a new rear arm and go riding.
Any help is appreciated
better check the shock it mite have a problem if up tore off the shock mounts or you hit something hard.
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
smoothride said:better check the shock it mite have a problem if up tore off the shock mounts or you hit something hard.
thanks for the advise. the shock looks fine, but it is not really an issue since i have a spare shock if i need it. just need info on what other rear arm's will work with my sled
ROCKRTX
2010-2011 have bearing in the lower mounting location so it will not bolt on....they also made new rail in 2010 for the mono.
2009 will fit ok
2009 will fit ok
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
THank you very much
RippinV
You might want to just send your existing arm/Arms out to Half Baked. They reweld and beef up the arms and re-powerdercoat. They did all three of my sleds and all came out perfect. Have over 3500 miles on the arms now and not any problems and the powder coating looks brand new. I think you can probabbly get it all done for less than the cost of one new arm. They are also a site sponsor!!
ROCKRTX
ROCKRTX said:2010-2011 have bearing in the lower mounting location so it will not bolt on....they also made new rail in 2010 for the mono.
2009 will fit ok
This reply was for the front arm....
Rear arm will fit to 2010 model, 2011 mono 128" does not have the wheel mounted on the top shaft so it will not fit.
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
RippinV said:You might want to just send your existing arm/Arms out to Half Baked. They reweld and beef up the arms and re-powerdercoat. They did all three of my sleds and all came out perfect. Have over 3500 miles on the arms now and not any problems and the powder coating looks brand new. I think you can probabbly get it all done for less than the cost of one new arm. They are also a site sponsor!!
if you re-read my post i already had halfbaked do the upgrade on my suspension arms.
They only reinforce the front arm. i sheared the mounting brackets off of the "REAR" arm
Thanks for trying to help
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
ROCKRTX said:ROCKRTX said:2010-2011 have bearing in the lower mounting location so it will not bolt on....they also made new rail in 2010 for the mono.
2009 will fit ok
ok so you are saying that the rear pivot arms from 2006-2010 are interchangable?
i will look into a little deeper before ordering anything. if everything checks out and is actually interchangable i will order either the 2009 or the 2010 pivot arm.
the 2009 is $157.00 and the 2010 is $200.00 wondering why the big difference in price?
Thanks for your help!!
Super Sled
- Feb 25, 2009
- Summit X
RTX said:i will order either the 2009 or the 2010 pivot arm.
Thanks for your help!!![]()
I guess that is the $43 dollar question..... If you find out, please report back and let us know.
- 6K
