markowinnipeg
Just going though skid and greasing wheels and wondering are the outside rear axel wheels regreasable? The middle wheel has a spring clip then you can grease the bearing however the two outside wheels have a metal washer in them and does not look like you can get to the bearing.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
The stock outer wheels do not have replaceable bearings but if you replace them the new ones from Yamaha will.
markowinnipeg
YammyRX1 said:The stock outer wheels do not have replaceable bearings but if you replace them the new ones from Yamaha will.
Thanks, I was checking parts site and Yamaha wants 72.00 per piece out of the states, anyone know of a good after market wheel?
Nytro Nork
If you go to their web sit and look up oem accessories you should be able to get the wheels for 25 bucks or so and they have replaceable bearings.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
If you don't mind them being plain black just use the inner type for $25.00
markowinnipeg
canoehead said:If you don't mind them being plain black just use the inner type for $25.00
Wow thanks I will do that, saves my a hundred bucks and honestly I can live without the lighting bolts.....hmmm maybe they make the seld faster
