J-fuzzy
- Feb 28, 2019
- Upper Michigan
- 2014 SR Viper LTX
- Escanaba
im going to stud my track but was told to get a rear heat exchanger protector but can’t seem to find any? I keep getting sidewinder ones showing up
Shouldn’t need any as long as stock ones are still in there.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
As far as I know the Sr Viper does not have a rear heat-exchanger. The tunnel protection came stock from factory on my 14.im going to stud my track but was told to get a rear heat exchanger protector but can’t seem to find any? I keep getting sidewinder ones showing up
J-fuzzy
- Feb 28, 2019
- Upper Michigan
- 2014 SR Viper LTX
- Escanaba
Inside my tunnel by the jack shaft I have what to me looks like a heat exchanger. I thought it was called a rear heat exchanger?
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
You might be right.
I call that a forward mounted heat exchanger. I have never seen it protected from studs. It sits pretty far away from track but someone here may have better info.
I have never seen protectors for the front exchanger.
cobrajet ltx dx
- Oct 5, 2014
- pa
- 2015 yamaha ltx dx
No tunnel protection required.
No rear tunnel cooler= no ice buildup or huge ice chunks.
Radiator/fan and front cooler= almost 0 overheating with a properly working cooling system.
On of the best designs on the viper IMO.
J-fuzzy
- Feb 28, 2019
- Upper Michigan
- 2014 SR Viper LTX
- Escanaba
Ok good to know Thanks
