Boston RX1
I am putting on a mountain rear heat exchanger. Do I need protection, or is it high enough in the tunnel. After looking at my setup, if I have problems with the track hitting the exchanger, that's the least of my problems. I can't see anyway the track will touch, ever.
Indy
Boston RX1 said:I am putting on a mountain rear heat exchanger. Do I need protection, or is it high enough in the tunnel. After looking at my setup, if I have problems with the track hitting the exchanger, that's the least of my problems. I can't see anyway the track will touch, ever.
why dont you do a poll? 8)
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Check out my experience.
http://www.rx1.info/viewtopic.php?p=672 ... ght=#67264
better safe than sorry
mikeb
it will .............. believe me!
I put protection in and it wasn't enough. I scratched mine this weekend. I'm going to add to it
rhoag
I was over heating up in Muni area this weekend and had antifreeze spewing out. I took it to the dealer today to have the system pressure tested. IThey have a rear heat exchanger kit for 48 bucks that I plan on installing. Since my ripsaw isn't studded do I need rear heat exchanger protectors????
stinx
I posted apicture of the set up I had made for my warrior. THe rear heat exchaner needs a guard.
PARX
04 shorty, do i need protectors or not for rear exchanger, price from yamaha $41, thanx guys
Boston RX1
I got a price for the mountain OEM rear exchanger for $110.00. What are you guys getting for $50.00?
stinx
My local stealer ordered it for me . I paid $88 HUdson cycles in Hudson NH. When I ordered mine, they said they were going to order several more to keep in stock.
gnip134
PARX
04 shorty, 8ET-RHECR-KT, $42
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
The shorty exchanger is half the cost because it's half the size.
