Jay Jager
- Aug 2, 2014
- Prescott Ontario
- 2010 Vector GT
I just got my new to me 2010 Vector GT into my shop for a good look.
Started to set up my suspension when I noticed the rear shock dampener remote adjuster is not working.
It looks like the cable that runs to the shock has snapped.
Is this common?
Is this common?
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
Yes this is common. Barn of Parts has made up a key type adjuster to fit onto the shock which will always work.
Cemoto
- Mar 22, 2015
- MA/ME
- 2011 RS Vector LTX
Mine broke last year. I thought I had blown the shock. So I took it to a dealer hoping the blown shock would be covered by the YES warranty. It turns out it was the cable and the dealer said it happens all the time. Wish I knew about the BOP fix, thanks for the heads up Handy.
Jay Jager
- Aug 2, 2014
- Prescott Ontario
- 2010 Vector GT
Thanks for the info guys.
I will get it set for now.
Look at a new one if I sell down the road.
Jay Jager
- Aug 2, 2014
- Prescott Ontario
- 2010 Vector GT
I just ground the end of an old key off square so it will fit the cable slot. Not as easy if it is cold and frozen but will let me adjust when needed. I pulled out the old cable, cut the tube off, filled the end with silicone and replaced to keep any crap out of the slots at both ends.Yes this is common. Barn of Parts has made up a key type adjuster to fit onto the shock which will always work.
Sleddog1
- Sep 19, 2015
- Niagara Falls
- 2000 SXR 700
2008 Vector GT 40th Anniversary
2014 Viper LTX
do you have a picture of the key you made? I have the same problem.I just ground the end of an old key off square so it will fit the cable slot. Not as easy if it is cold and frozen but will let me adjust when needed. I pulled out the old cable, cut the tube off, filled the end with silicone and replaced to keep any crap out of the slots at both ends.
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
If your gonna eliminate using cable just flip shock 180 so adjustment is facing down, much easier to adjust on ground.
Jay Jager
- Aug 2, 2014
- Prescott Ontario
- 2010 Vector GT
Sorry I am away working and don't have a pic. Pretty simple, just grind off an old key so it fits the square slot.do you have a picture of the key you made? I have the same problem.
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
Or just call Travis for a nice made one.
Sleddog1
- Sep 19, 2015
- Niagara Falls
- 2000 SXR 700
2014 Viper LTX
Ok . I'll try it. Thanks
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I noticed my cable was broken recently and removed it completely and covered the open hole in the tunnel.I ended up turning the shock 180 degrees so that the rebound adjustment screw faces downward for easy access.
I now carry a stubby #1 Robertson screwdriver and use it to adjust rebound as needed. The screwdriver fits perfect.
Sleddog1
- Sep 19, 2015
- Niagara Falls
- 2000 SXR 700
2014 Viper LTX
I flipped my shock as well. I'll try the Robertson screwdriver ,thanks.
Metallicat
My 3rd replacement cable broke, will not replace with another new cable system. I'll probably buy the BOP adjuster next fall.
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
Has anyone had any luck with the new superseded part number for the remote adjuster? I just want to know if it’s worth spending over $100 on this new part number. Does it hold up any better? If it’s not any better then I’ll go with the Barn Of Parts fix.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Don't bother. As others have said, #1 Robertson stubby works perfectly. I set mine at 12 clicks and never looked back.
