Bubb Rubb
Has anyone had any luck getting the Y.E.S. to cover the replacement of the remote adjustment cable leading to the mono-shock rear suspension from the tunnel adjuster on a Vector GT? It has broken twice because of ice build-up under the tunnel.
They covered mine the 1st time but would not cover it the 2nd time
even with the YES program. What good was the warranty if you can't use
it. They know they had a problem with this cable that's why they updated
it later.
it later.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
TrueBlue said:They covered mine the 1st time but would not cover it the 2nd time
it later.
When did they update this cable?
radianguy
- Jan 1, 2007
I had mine replaced under warranty, was told I got the updated cable. That was spring of 08.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
Am i safe to say that 09 vector has updated cable?
Yes, that should be the newer cable but that doesn't mean it won't break.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
Any way to protect this cable from breaking?
Do a search for this topic. Somewhere on this forum someone covered or re-enforced the cable to beef it up.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
Will do thanks!!
- 6K
