Vector Julie
Does any one know who makes the Clicker Knob Adjuster that mounts directly on the Monoshock body on non OLIN Shock model Apex/Attak/Vector sleds.
I want to eliminate the remote dial/cable that is mounted at the tunnel.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
I'm not sure anyone makes a Clicker knob that retro fit's the cable end . After my last rebuild I removed the broken cable and using a small screw driver with a no. 1 square bit adjusted the shock manually. You can fell it click for each turn. I put a small rubber cap over the end of the adjuster to to keep ice out.
DGZRT
DGZRT
