Rear Suspension Adj cable
PEI Canada
Canada
2006 Attak
Hey Guys,
Is it ok to put a bit of oil or grease inside the shock adjuster cable. just thought it may help it from freezing and add some lube.
Im sure it wouldn't hurt but what works better than grease is throttle cable lube. Maybe a dab of grease on each end before you put it together.
If using grease use a synthetic grease or a grease designed to work in low temps. Regular grease may make it difficult to adjust when cold.
