rx1 fern
hi ,i have an 08 nytro rtx and i was just looking at my rear suspension and found at the front of rear suspension there is a cable with a metal spring around it that has an eye inlet on the end of it.where does it go .can someone post a picture of where it goes please and thanks .i tried to find it and couldnt thanks for any help.
rx1 fern
it is also hooked up to a round cylinder .must be a reservoir for one of the shock.but where does the end with the eye inlet go to ,cant figure it out .
towerrigger
The end of the eyelet should go into the bottom of the shock.
rx1 fern
i guess that means the bolt backed out then .thank towerrigger.do you know the size of bolt needed thanks.
rx1 fern
towerrigger .what is the purpose of this cable then .does oil go through it then .thanks.
gunner2
You have to pull the rear skid out Remove the shock and the cly and braided hose,check the shock for damage,If no damage then you will have to get your shock repaired/rebuild and recharged.Who ever rebuilds it will reattch the braided line.
rx1 fern
just took the skid out to see what happened.first day i had some free time.what i noticed is the bolt is missing.what do i do now.the shock looks good and threads look good .have to get new bolt from yamaha.what do do now.can i pour some oil in the shock hole and put the hose back in with new bolt.thanks for any help.
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
rx1 fern said:just took the skid out to see what happened.first day i had some free time.what i noticed is the bolt is missing.what do i do now.the shock looks good and threads look good .have to get new bolt from yamaha.what do do now.can i pour some oil in the shock hole and put the hose back in with new bolt.thanks for any help.
Shock will need to be rebuilt/recharged.
rx1 fern
thanks revster.where is a good place in manitoba to send it too.
