2stroken
Anything to do on the clutching to make it not throw you over the bars when you let off the gas?
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Any mods? CLutching? Yr make model?
Could have possibly been something you tinkered with recently. I know they engine break, but not enough to flip you over the bars.
2stroken
Haven't messed with anything, the flipping over the bars is basically when I am hanging off on one side and let off the gas. I then go boom!
ATV PRO #11
- Jan 22, 2011
Keep practicing
Or just stay in the middle of the machine. If your flippin off when riding off the side that could get dangerous.........
You can, back off or add the secondary helix 10* and try it to reduce the backshift. (engine brake) Go one each way.
Takes 10 mins to pull and adjust secondary. Played with mine the other day and never been in there before.
There is a good Helix chart postes in "Voda's 136" thread"
Maybe someone has been in there before. Stock should be A1 if it's an MTX B1 (no idea what your machine is)
RIGIDONE
Ulmer clutch kit, you will be able to roll into the corners and actually use your brake, rather than trying to guess how much the engine is going to slow you down..
2stroken
I was hoping I could get by with just a simple cheap change.
Also they don't list that clutch kit for an MTX
RIGIDONE
Maybe shoot Ulmer an email and ask about the mtx clutching..His kit works very good, at $120 its a pretty good deal IMO. I have stock arms and a spring if you want something to mess with.. Maybe $20 shipped if you want them?? They have been collecting dust for the past 6 years..If someone could use them it would be cool..
2stroken
I would be interested shoot me your contact info
xt_gt
Clutch kit will help. Engine braking won't be as aggressive.
ATV PRO #11
- Jan 22, 2011
Cheapest way to do it is to roll into the corner 1/4 throttle on the gas, don't let off and use the brake to help guide you around. It's free, and a braaaaptastic way to rail a phazer around tight twisties
