ygini
- May 28, 2024
- France
- Other
- Experimental aircraft with Yamaha Genesis 80FI
Hello
Uncommon usage here, I'm a french aircraft pilot and builder, I've mounted a Yamaha Genesis 80FI on a microlight aircraft (CFM Shadow) and it works really well!
I'm trying to get deeper knowledge on the engine as of course, Yamaha does not support this kind of initiative, and deep technical informations are not publicly available for that engine.
So far my main source of information is the Phazer 500 maintenance manual, and it did the work.
Now that the engine works and the aircraft fly well with it, I'm trying to get reading of the oil pressure on my EMS (a Kanardia EMSIS).
Built-on the engine, there is the oil pressure sender 8GN-83651-00-00 which is not used by my ECU harness (simplified one for aircraft needs) and I'm trying to read it.
However, this sensor is not documented in the Phazer 500 maintenance manual, only the pressure switch is, not the sender.
The sender is a 3 wire sensors, so I guess it's a voltage divider but I cannot find any specifications on how to use it.
Does someone here know this sensors and can tell me usage of each wire position and reading specifications to get the actual oil pressure?
Cheers
Yoann
Cheers
Yoann
ygini
- May 28, 2024
- France
- Other
Uh… No one know this sensor?
DARKMAN
- Sep 27, 2023
- Harris, MN
- 2013 APEX SE
1981 ET340 "Frankenticer"
1982 SS540
1981 ET250 Mod Oval/Lemans Racer
If it is 3 wire it is likely ground (low reference), 5 volt reference and signal wire. As pressure changes the voltage at the signal wire will change between 0-5v, which voltage pertains to what pressure? Who knows?
ygini
- May 28, 2024
- France
- Other
That's exactly the question: who knows?If it is 3 wire it is likely ground (low reference), 5 volt reference and signal wire. As pressure changes the voltage at the signal wire will change between 0-5v, which voltage pertains to what pressure? Who knows?
Is it a 5V? Or a 12V?
Which wire is what?
And what are the pressure represented by 0 and VCC?
I cannot find any electronic chart for that specific part number…
