GIMME SNOW
Fusion said:Gimmesnow...that's my sled as well. Did you use any additional adhesive, or just heat gun and application of std. decal?
I'm going to put mine in the same place.
Seems you must have had yours through last winter, how did you like it, and is it studded?
Fusion.... No I didn't use any additional adhesive, just some rubbing alchohol, and a hair dryer.
Best sled I've owned, is this you first Yammie 4-stroke? Yes I did install studs, 162 down the middle
RayandPaula
Hi,
Here's the method I use on my snowmobiles and boat.
1) Clean area with rubbing alcohol.
2) Make up a spray bottle of water with a drop of dish soap.
3) Peel off sticker and spray the back side soaking it.
4) Spray area heavily where you want it.
5) Place sticker on, spray a little more on the surface of the sticker and press out air bubbles from the center out either by a small plastic squeegee or rag.
By doing the above method it gives you time to position it perfectly where you want it. I have done this on both smooth and textured surfaces. I have "never" had one come off and not even a corner lifting. I follow this method on every sticker I apply.
