gun nut
Help,
I can't get the cover off my chain case. I got the bottom to open a bit, but the top seems like it's still got a bolt holding it.
I downloaded, and printed all the instructions I could find. They say "now slide the cover off evenly". There has to be a trick to it.
I'm changing tracks.
sherlock29
disconnect all your linkage... once it has come out alittle take a light and look down, reverse fork has to be lifted off bottom gear... when its sticky sometimes its the bearing in the cover that is not sliding off shaft, i've even had to take some emery cloth and rub down any high spots on shaft.. especially where the keyway fits for the rotor.. takes alittle palying with... just becareful not hammer away at it.. and if so.. use rubber mallet. it will come just needs some elbow grease.
And of course... make sure all bolts are out.. hehe..
gun nut
chaincase
I hate to admit that my mechanic wife came out and found a bolt, I missed.
ZapeX2
I hope you told her you meant to leave that one there...lol... I hate it when they're right...
Re: chaincase
Ah, was it the small bolt in the middle on the reverse gear???gun nut said:I hate to admit that my mechanic wife came out and found a bolt, I missed.
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
That little bolt bites a lot of guys (lol).
- 6K
