Removing Chaincase cover on 05 RX1ER
wolfie
CT
Ok, it looks pretty straightforward. Removed the reverse linkage bolt at top (left rest of linkage attached to case) then the two screws holding the brake caliper, two allen screws holding the parking brake, clip holding the disc on with spacers, then two large bolts and 3 small ones holding the chaincase. Thought a few wacks with the rubber mallet and it would break free. Still seems to not want to come off.....am I forgetting something?
There is a 10 mm bolt in the center of the cover it need to be removed.
Thanks very much for your replies, I definitely appreciate it. I forgot to mention, that even though I didn't know what the bolt was for, that I already had removed the 10mm bolt.
Hey you guys forgot to tell me about the torx set screw on the collar that fits behind the disc :tg: Looks like Lazy was right though, the reverse linkage was too tight. I took everything apart cuz I wanted to make sure those noises I was hearing occasionally weren't doing any damage. They weren't. All better now.
