rough rider
has anyone tryed a gas shock on the rear skid to replace the fox float on a 141?? im thinking about getting the viper S-TX DX with the coil over shock on front suspension and 141 with fox float, I dont want the float, iwant a smoother ride, is there any shocks that will fit, the guys that have a xtx have u tryed any other type of shocks. Decisions decisions. I also like the blue L-TX se
dfroster
- Dec 18, 2003
- Kronenwetter, WI
- 2022 Arctic Cat Thundercat EPS
Zbroz has an adjustable coilover rear shock with compression clicker to replace the float and they have a adjustable transfer block kit as well. I haven't read any feedback about either. Both make sense for the xtx skid to help improve the on trail ride and handling.
sfraser
I believe Elka has shocks for this skid as well.
vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
Hygear got answer for your problem give the a call
rough rider
I was checking the artic cat site, and the 141 procross suspension on a xf800 lxr 2012 model uses a fox zero pro coil over rear shock, 250.00 complete, Im thinking about getting the s-tx dx viper, and want to get rid of the fox float, because if that shock blows or looses air u are screwed also sounds like a much plusher ride
