petegowa
- Oct 23, 2018
- Raymore, Sask
- 2014 yamaha sr viper xtx se
will the rear shock off a 2016 153 sr viper mtx
fit on a 2014 sr viper xtx 141
want to change fox float 2 to a coil over shock on the rear shock on the skid
read on here some place that the 141 153 162 are the same
just that the rails are longer
I have heard same thing. Will look up specs tomorrow for you. Remind me.
petegowa
- Oct 23, 2018
- Raymore, Sask
i was looking around at some specs
its tuff to get a straight answer , this is what i found so far
2016 mtx 153 srv10m2 is the one and only sled i could find with coil over rear shock
will it fit a 2014 xtx cant find a simple answer
shock 8LM-G7480-00
spring 8KG-G7489-00
sold seperately much cheaper than other shocks
shock 8LM-G7480-00
spring 8KG-G7489-00
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
All the REAR shocks on 141-153-162 are the same length, the Center one does differ between years/lengths though. Buddies 15' MTX came with a coil over all around, his is the Black non-SE 153.
petegowa
- Oct 23, 2018
- Raymore, Sask
thanks
yes it looks like the 2015 black mtx viper shock will work
Thats not what I found. M series are not same length and our numbers are same as Cat.
petegowa
- Oct 23, 2018
- Raymore, Sask
well ok wouldnt be that easy would it
will do some more looking around
maybe 4 inch of snow here so cant ride anyway
also was melting here all week just sucks
Matt Daniels
- Nov 26, 2016
- Brighton, MI
- 2017 SR Viper XTX SE
We just put a MTX rear shock on my buddies 2014 XTX. Put 450 miles on it last weekend in the UP. After a slight break in period , he said it rode great.
petegowa
- Oct 23, 2018
- Raymore, Sask
good to hear
could you find out the year and part number for that mtx shock
shock im looking at is 8LM-G7480-00-00 off a 2016 mtx
and i have to buy spring seperate its part is 8KG-G7489-00-00
thats from yamaha catalog
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Both the 137 and 141 get the XF name on cats, which gets confusing when cross referencing since it’s 2 different skids. That chart above lists shock length for the XF 137 (Viper LTX). I bought a used Evol r out of a Cat 153 to try out and it’s the same length as the Float 2 in my XTX.
petegowa
- Oct 23, 2018
- Raymore, Sask
what is the difference in these REAR shocks
2014 xtx shock 8jr-g7480-00
2015 xtx shock 8jr-g7480-10
2016 xtx shock 8jr-g7480-20
2015 mtx-se 153 and 162 shock 8jr-g7480-10 both same
2016 mtx-se 141 153 and 162 8jr-g7480-20 all three same
2016 xtx se shock 8jr-g7480-20-00
2014 is 00 at the end of part number
2015 is 10 at the end of part number
2016 is 20 at the end of part number
are the shocks actually different or just different last numbers for different years
Matt Daniels
- Nov 26, 2016
- Brighton, MI
We installed rear coil over shock from 2015 MTX on the 2014 XTX. Sorry not sure on part #
petegowa
- Oct 23, 2018
- Raymore, Sask
no prob
looks like the mtx coil over will fit
thanks
thanks
